Mark42
- Oct 8, 2003
- 9,334
In another post about control box test horns I learned that my control box does not do an automatic test beep of the horn. I can add a micro momentary switch to manually test, but thought that it would be cool to add a component or two to the control box to sound the horn when the ignition is turned on. <br /><br />I went to Radioshack.com to find some timer chips, but not having any experience with these type of components, I am at a loss as to how to use them properly.<br /><br />What is needed is a circuit that will can trigger a relay for 1 or 2 seconds when energized. When powered off, it will reset and trigger the relay for 1 or 2 seconds again the next time it is energized.<br /><br />I already have some micro relays that will handle the current/voltage when grounding the horn. My problem is how to trigger the relay for 1 or 2 seconds then stop while the ignition is still on.<br /><br />Any suggestions as to what components I need and how they interact? <br /><br />Thanks!<br /><br />Mark.
