help needed on lower unit of 1998 yamaha 250
hytymadi
i had water in the gearoil after looking over everthin i found out the bearing housing for the perpeler shaft was cracked and the o ring was sticking out the side i need to know how the get the shaft and the bearing housing out i tried a slid hammer and can't seem to move it i need to know if there is something that i am missing.. on taking it apart thanks
thanks Jeremy Babson
stylesabu
Master Chief Petty Officer
Re: help needed on lower unit of 1998 yamaha 250
lower unit has to be dropped. post picture, sounds like you gonna need a lower unit antway
hytymadi
yea i have the lower unit droped i just need to get the shaft and bearing housing out to see if i can be fixed
rodbolt
if your trying to pull the shaft and carrier by using a slide hammer attached to the prop shaft you have to remove the shift shaft first.
to pull just the carrier I use the puller legs from OMC and oxygen acetylene.
if its a left hand case the carrier and propshft come out as an assy after removing the shift shaft.
hytymadi
Rob, thanks for the reply. Yes we are using a slide hammer. We thought about using a little heat on the casing but was worried about warping the housing. We did remove the Shifting shaft and tried the hammer without luck. And you do think a bit of heat will help? Thanks for the help, Jereme
rodbolt
yep.
I go through several bottles of heat every year.
saltwater is wonderful stuuf.
hytymadi
thanks rod for all ur help i will try the heat and lit u know how everything works out.. and thanks again that info was price less
thanks jeremy
mswalter2009
Like I told your Dad, Rodbolt is the man. This is a great forum. There are many knowledgable people who contribute. Welcome to iboats and good luck with the repair.
Mike
Mt. Pleasant
