I want to replace the prop on my Mercruiser which I believe is a 230hp small block V8 around 1984. The prop has the characters "48 78118 A40L 17P" (With a small vertical mark after the 48). It is a black aluminum 3 blade prop, probably a black max.
Does anybody know where I can confirm the make/model/specs of this prop so that I can look for a replacement? I am looking for something that will give me a little more power out of the hole. The boat is quite heavy for this engine - a 23 foot deep V cruiser (Bertram 23 like) and weighs around 5000-6000lbs laden. Does around 38mph. I am thinking a 4 blade Stainless Steel replacement.
Also, here are some photos of the leg.
Is that an Alpha leg or pre-Alpha?
