Help needed
zman84
I have a 60s 10hp johnson the old stile pressurized tank is giveing me fitts not sure if something is dammaged it wont hold prime without the use of prime bulb advise of where to start to find my problem would be much app :)
66evinrude
Re: Help needed
make sure your lines are tight on carb and gas tank ,and make sure gas cover is tight, make sure the gasket on your gas tank is not leaking hope this helps
Tim Frank
Re: Help needed
It does not make sense that you have a pressure tank and a priming "bulb".
Is this a tank with a double gas line? Is the bulb that you mentioned in-line?
