help, new fuel pumps and pressure still below specs 2004 5.7 MPI
2004 searay
hi, i have a searay with a 5.7 MPI engine, bravo drive, serial # ow027371, this has the fuel pump under the port side engine mount. i had a problem last season with no power and diagnosed as low fuel pressure, 28psi and 32 with reg unplugged. over the winter i replaced both pumps with OEM units and the fuel regulator and filter screen down below. now i fire it up and i am only getting 30PSI and 38 with regulator unplugged. . i checked the fuel supply line and thats ok, ran a seperate tank of fuel to the input line, tested the power to the low pressure pump, and the high pressure pump i can hear run so i know the power is getting to that one. i am so sick with this issue, i spent a lot of money on OEM parts and to still have this problem is so discouraging. i also tried 2 different fuel pressure testers, both give the same info.
2004 searay
860349A 1​
which when i looked it up thats the # i came up with but now states :
Fuel Pressure Regulator Regulator mounted on fuel cooler
No color mark Fits MCM/MIE 7.4L/LX MPI, 454 Mag MPI, 502 Mag MPI & MIE 8.2L MPI
the one it calls for is :
861126A1 Fuel Pressure Regulator
Mounts on fuel cooler.
Fuel pressure regulator 861126A1 is for use on MerCruiser 4.3L, 5.0L, 5.7L and 6.2L MPI stern drive and inboard engines with ECM 555. Also for use on MerCruiser 7.4L MPI (L29), 454 Magnum MPI, 496 Magnum and HO, 500 EFI and 8.1S and HO engines. See your owner's manual or service manual for specific application and instructions
i know the part # is wrong but based on the description, it should work, no?
alldodge
860349A1 Cool Fuel Gen 1 Mallory 9-33207 (36 psi)
861126A1 Cool Fuel Gen 2 (43 psi) BLUE Mallory 9-33206, Merc 892681
Not enough pressure and if it wasn't a MPI with all the sensors it may have burned a piston from a lean condition
chs marine service
how much pressure do those HP pumps put total? sounds like they use the same pump for multiple systems.
2004 searay
im sick to my stomache. i cant believe i have to pull this motor again when i broke my ass doing it the 1st time.
alldodge
I guess its way to hard to get at pump in the boat?
dubs283
Have you inspected the fuel supply to the fuel pump?
A fuel vacuum test will indicate an issue with the fuel line and fuel tank supply.
Lou C
A 2004 boat is old enough that the anti siphon valve could be bad, fuel pick up screen clogged etc. Ever try testing pressures with a remote tank? I’d for sure do that before pulling the engine again.
It’s stories like this that make me glad I still have a simple engine with a mechanical fuel pump ($75 to replace) and a 4 bbl Quadrajet ($60 to rebuild).
And if I re power it that’s how it’s going to stay.
alldodge
Good grief guys it's not a fuel supply issue it's a fuel pressure issue
Lou C
Other than low voltage to the pump and low fuel volume to the pump if everything is new with the correct parts installed what else causes low fuel pressure?
alldodge
The regulator, Please read the thread
dubs283
OP states fuel pumps and regulator replaced with oem
Untethered vacuum reference pump should supply above spec pressure regardless of regulator
A fuel pump with no restrictions regarding supply ought to produce viable numbers for testing. OP's does not
It's time to investigate fuel supply (to the pump) issues
Lou C
What I said. I recall reading that Merc revised these cool fuel modules because of problems in the field, I wonder if that has anything to do with the OPs problem of low fuel pressure. Are you sure that the parts used are correct?
Also while there may be 12v at the connector what happens when the load of the pump is on the circuit? The pump(s) draw how many amps? What about the terminals for the relays? This was a problem on certain V/P EFI engines, low quality relay holders with corroded terminals = high resistance.
alldodge
No
Regulator which was installed is
it's a 36 psi Reg and he's getting 30 to 38 psi on gauge. Given all gauges are +/- a bit, shows Reg is working correctly
Motor need a 43 psi Reg part number
which is the correct part number for his motor serial number
How is this a supply issue?
dubs283
Again, regardless of presently installed regulator the pump should provide above maximum spec pressure when the vacuum reference line is disconnected
OP has performed this test and the fuel pump (oem) hopefully installed correctly does not provide spec pressure
Not saying you're wrong about the regulator, Im thinking a pump fed weak supply will provide weak supply, ymmv
alldodge
Guess we'll just agree to disagree
Pump and Reg is new ans OEM
Reg controls max pressure. Only way to get more then max pressure is to block off Reg return back to fuel filter
dubs283
If equipped as such
Mercury didn't utilize this system much. Iirc it was used on a 7.4 mpi gen v with a vst and mechanical fuel pump. This is pretty esoteric
We don't know OP serial number/setup, guess we can guess
Did you ever locate the seal on your monitor bottle cap? Pardon the digression
