So here is the deal. I just bought this boat set up. 14ft 1997 sea nymph 50th anniversary with a 40hp 1997 Johnson electric start oil injection and power trim. When I bought it 4 days ago the guy turned the key and it started with no issue on one key turn. When it it started the motor was revved real high so he tuned it back down to a low idle and it ran smooth and both gears worked fine.
I'm a novice starting electric starts so I'm guessing the issue is simple. I just charged up the deep cell and hooked it up correctly. radio worked, power trim worked and when I was turning the key the fly wheel spun fine and just didn't start. I realized the safety lanyard was missing and the key was pushed in. After I was able to pull the key safety out which it just stays out without a lanyard the motor does what you see in the video. Gas is primed, and everything has power but the fly wheel is not spinning smoothly. All I do with the throttle is leave it in neutral right? It wont even turn if it is moved forward or back at all.
I feel dumb asking these questions but I need your guidance on what is going on here. It just ran great 4 days ago.
Here is the video - http://youtu.be/lfYF9-scNXQ
Thank you in advance!
