22E6441
- May 29, 2008
- 376
This is for my 1990 Johnson 50 as per my sig.
I just rebuilt my carbs, and and mechanically had no problem.
When I was reinstalling them, the only thing that got disconnected electrically was the fuel primer...because you have to disconnect it to move it to replace the fuel lines. Hooked it back up the same way it came off.
I had unbolted the starter for a minute to give me more hand room while reinstalling the carbs, but didn't mess with the wires.
I previously had no electrical issues that I knew of.
I rebuilt my carbs because we suspected a clogged high speed jet was causing the boat to sputter at medium to high throttle under load. It started and idled just fine.
No it's not doing anything at all when I turn the key.
The battery is good.
The kill switch thing is on.
The boat is in neutral (can't move the fast idle arm if it's not)
I don't see any fuses anywhere to check.
My Seloc manual isn't much help with this....
I'm lost and need guidance.
I have a multimeter for testing anything.
Please help.....I was so proud of myself for rebuilding the carbs, but now this just stinks.
