help now/cant send resume as attachment
yourkiddin
when trying to send resume as and attachment i get this error. file format not supported by installed converters. i cant find where to go on my computer to fix.
MTboatguy
Re: help now/cant send resume as attachment
What format is your resume in? you can normally save as Rich Text Format and it should attach, or convert it to an adobe .pdf format, there are many places on the web you can convert it to .pdf which is pretty universal.
yourkiddin
thanks for your help. could you be a little more specific. my head is busting. trying to get this job. i am just not that computer savy. maybe just point me to sights if i have to download. im not total idiot and can probably figure it out with just a little more detail.
Haffiman
Right click the file you are trying to send.
Scroll down to;Properties
Left click.
Which prg comes up under 'Open with'?
MTboatguy
What program did you write your resume in?
dolluper
Converting Text Files
Most word processing programs provide an Import function, which provides built-in conversion for various document formats. Simply select Import from the File or Import menu and choose the document type you want to input.
If your word processor does not import the document type you need, you can usually use the ASCII file format as a common denominator; however, you will need the word processing program that created the original document.
If both word processing programs import and export ASCII files, convert your original document into an ASCII file using the source word processor. Look for Export in the File or Export menu. Select ASCII file or Text File. After creating an ASCII file of the source document, use the destination word processor and import that file using the Import option, again for an ASCII file or Text File. Note that all format commands (bold, italics, headers, footers, etc.) will generally be lost between conversion
joed
What email are you using? It shouldn't matter what the file format is when you send it. It should just attach the file as is. If it is a strange format the receiver might not be able to open it.
Tim Frank
Yeah.
Bob_VT
You have a PM
yourkiddin
thanks guys i actually struggled through it. once i set it to the rich text format i was able to send it.
MTboatguy
Actually, I can set what types of files can be sent through the servers I own, of course they are set up to pass on the most common formats, but I did have to add a format a few months ago, when our customers started using Open Office and sending native file formats..
But .rtf is always a safe format, that is pretty much cross platform compatible.
