Help on choosing fuel tanks
1970Thunderbird
Hey,
I'm going to install two fuel tanks in my 17' tri-hull, but I don't know which sizes to go with. I'm going to install identical ones, and I figured I'd use two 12 gallon tanks.
If I want to be able to run for most of the day, will 24 gallons be enough? I have a 1978 80hp Mercury on the boat. I'll be using the boat for cruising, fishing, and maybe some skiing. I don't know the fuel consumption for the motor, unfortunately.
So, are two 12s going to be enough? Or should I try to get some 15s or 20s. My only concern is that those tanks will be almost too large.
Thanks!
a70eliminator
Re: Help on choosing fuel tanks
That's alot of fuel, I have a 16' with outboard 80hp and 2 6gal tanks one in the bow one in the stern both are portable, I have to manually switch them out. There are times I wished I had more fuel, and a bigger boat.
sorry can't give much advise other than take some measurements and go from there, there are many shapes and sized available.
1970Thunderbird
How long does 12 gallons last you?
I was going to install both of mine in the rear, and run them together, with a valve so I can alternate between tanks. Or maybe I should just run from both?
a70eliminator
About 10mi off the Erie shores using the 1/3rd 2/3rds method with plenty left over, pulling the kids on tubes eats it up but we get tired out before the gas is gone.
a70eliminator
It's a practice of using 1/3 of your fuel supply to get out and saving 2/3rds to get back in.
Lion hunter
Thats about 150lbs of fuel + tanks in the back of the boat. If you use the 10% of HP rule you'll use about 8 gal/hr at WOT. 24 gals would get you 3 hours apx. at WOT. Are these permanant tanks hooked to fill valves? My old 16' glastron tri-hull w/ a 100hp Merc had 2 10gal tanks. I don't think I ever used it all but it was nice to no it's there if you need it. I run a 16' with a 60hp and 12gal fuel. I'll usually use it all fishing because I run up the lake about 1/2hr, then switch to my kicker which uses almost nothing to troll, then back to the dock. I'll usually have a couple gal left when I get back. If I'm just playing with the kids I'm close enough to the truck that I just carry extra fuel there and fill up at lunch. I like to get out a BBQ and stretch.
1970Thunderbird
Lion Hunter,
No, these are portable tanks that I bought at West Marine. I ended up getting two 12 gallons. Anything above that and it got into the permanent tank range and the price easily doubled.
