help on merc gimball ring
bolo789
hey guys can someone help me getting the top swivel shaft out of the gimball ring.<br /> the ring is broken and i need to replace it, thanks much, everything else is pull just need to get that bolt out
JasonB
Re: help on merc gimball ring
Are you using one of the kits that has you drill the holes on either side of the housing? That is what I did and unscrewed the nut on top of that shaft with a chisel and hammer.<br /><br />There is a copy of the instructions here: Gimbal Instructions
