!!HELP!! on vaction in keys
BKOben
Im on vacation in the keys and I have to replace the head gasket on my 1991 3.0l merc 4cly. I need to know how many pounds of torque do i put on the head bolts and also if u can the valve cover as well. I need this info today, as I am leaving the keys on sat. :eek:
hoot
Re: !!HELP!! on vaction in keys
seloc manual for 110/120/140 HP, 2.5/3L shows 90 to 100 FT. LBS for head. and for the valve cover, 55 INCH LBS. = to ~5 FT LBS.
BKOben
THANK YOU! Your a god! time to get me some more dolphin
hoot
no, no god. but how many times have you heard this "i did stay at a holiday inn last night!" the manual also gives the procedure. tighten from the center outward alternating from side to side. tighten 1/3 of torque value first, 2/3 second time around, and full amount last time. and i did find this; for mercury marine engine go to 130 ft lbs, and for gmc go to 100 ft lbs. good luck fishing, been to the keys, great place.
jackrg
BKOben, You should recheck the torque of the head bolts after you run it. I did the same job on my 3.0l and after a couple of hours of running, my torque went from spec. down to 60 ft/lbs.
