Re: Help outdrive delima
Jrocket, if you look at this from a business ($$) perspective,that boat, complete, in good running condition and no defects other than normal wear and tear is worth about $2,000- 3,000 with trailer. You said that the floor was shot and it was missing the outdrive. I am going to guess that there is probably other items that also need attention. I do not see any way to make this profitable, unless you can find a working, used alpha for less than 500 bucks.....that is hard, even on eBay.<br />I would pull the engine, make sure it is running well and sell it. I would then, try to sell or give away the hull. Last, sell the trailer. You will come out way ahead of trying to fix this boat and sell it whole.
