Help! Overheating 3.0, not impeller or circulation pump
Vetal
Hey everyone, really need some help with this one. 3.0 started overheating to 220F where the needle stops.
Inlet hose has water flow in it. Hose to exhaust 4 times out of 5 has no water coming out of thermostat housing, to be more specific: while engine was still barely warm, removed water hose to manifold and saw good flow. Restarted the engine in 1 minute and no water flow anymore, tried couple of times again - no flow.
Removed circulation pump, no cracks, no play, turbine spins with the shaft.
At this point I am completely lost, please help :)
alldodge
Welcome
No water flow is the pump housing, impeller or connection from pump to thermostat housing.
You say not the impeller, why? If you just replaced it, there could be a problem with the install.
Get a short piece of clear hose, hose clamps and barbed fitting from the hardware store. Place clear in between the drive hose and thermostat housing. Start motor and look for air bubbles
Overheat is lack of water flow.
Either no flow in....or no flow out
Is there flow from the raw water pump thru the hose to the thermostat housing?
Vetal
Like I said, I have decent (visually) amount of flow from inlet hose, when I remove it from thermostat housing. But no water flow out of the housing to the exhaust
alldodge
Remove the elbow to exhaust pipe boot. Look down inside to see if exhaust shutters broke up and are blocking the exit
Vetal
Pls explain why it would matter, if there is no water out of thermostat housing? I'm confused
Pull the thermostat assembly and remove what ever is blocking it. If you have water coming from the raw water pump to the thermostat housing, you should have water to the exhaust as that is a straight shot unless there is a blockage or there is no flow from the raw water pump
Running your motor without the cooling water, your rubber exhaust bits are now burned up. Flappers and hose should be inspected and replaced as needed
Vetal
I wanted to put circ. pump back on and measure raw water flow. Does it even makes sense to measure raw water flow if there is zero flow out of the thermostat housing?
Yes. Should fill a 5 gallon bucket in 15-19 seconds with motor at 1000 RPM. Should shoot a good 8"+ up when holding the hose vertical
However before proceeding since you stated you have water flowing from the raw water pump. Pull the thermostat housing apart and clean the blockage
alldodge
How do you know there is no flow?
and no flow meaning it's going to the Stat but not leaving the Stat
Vetal
Awesome response!
Vetal
Just wanted to update you guys. Problem hopefully found - intake water hose today when started engine shoot like a liter of water into the bucket and then nothing after :) So impeller/surroundings are probably shot, and were intermittently working yesterday, messing up diagnostics
charliedaubitz1
on the top of the impeller housing are the black plastic oringed sleeve with a white plastic sleeve that's a guide for a plastic tube that transfers the water up the I/o to the transom , check that tube for a hole in it, ( it just pulls out). Also are you able to drain you manifold. Mine was totally plugged and there is a hose from the water pipe about the position of the side of the carb that connects where the manifold drain is and it provides water to the manifold all the time. mine was plugged by rust in the bottom of the manifold.
Vetal
Sorry I don't understand what is this water pipe to manifold (except the one from the thermostat housing) :)
charliedaubitz1
at the manifold drain there are 2 hoses that snap on, follow the one that's NOT the drain hose.
charliedaubitz1
You got us all scratching are heads, I thought your first post was talking about items 29 thru 31 in link, but right now I have no clue
Lower drive
it's a hose that's connecting to the manifold drain that's screwed into the manifold bottom. not part of the lower unit. it goes to the hose going to the tstat housing. it's a 1/4" hose with a fitting like the speedometer fitting
on the front of the lower unit. It feeds water into the bottom of the manifold.
charliedaubitz1
alldodge
Think I figured it out, your talking about the newer single point drain system. It's mentioned in manual 26
While we don't know what year the OP's motor is, I don't think it's that new
