Would anyone know what is causing this problem, or how to fix it?<br /><br />I have a 225hp Mercury, and it begins to heat up at Idle or when I run the boat in reverse. The water stream looks strong, and the temp. is fine at running speed. But, if I let the motor idle a while, it heats up to buzzer level. I changed the thermostats, and the high pressure diaphram. Could it still be the impeller even though the water stream is strong??? Help please....
