disturbedklownz
- Apr 19, 2009
- 7
Ok heres the deal...Motor starts up fine idles fine and sounds fine.When i go to about 1/4th to 1/2 throttle it bogs out.Ill cruise it at the highest speed i can before it starts to bog down and then i reach back and squeeze the primer bulb real hard and hold it it will gradually start to take off and run fine.If i keep it running 1/2 throttle or more it does fine after that. If i stop and fish or go through a no-wake zone i have to do it all over again and hold the bulb till it will take off.
Stuff i have done and replaced and it has made no change to the way it runs.
-Rebuilt fuel pump
-Replaced primer bulb and lines
-replaced old filler hose that was all cracked.THe other hoses going from the -tank to the autoblend look fairly new
-Fuel Filter
-New plugs,did same thing with old ones
-tryed different gas and seafoam with nothing making any difference.
This is on a Ranger 335v and i really love the boat,its my first but i cant afford to take it to a mechanic.I dont know of any boat mechanics and i dont wanna get ripped off when they dont fix it. ANy help would be greatly appriciated THanks
-Rebuilt fuel pump
-Fuel Filter
