Re: help please BRAVO III duo prop gears ratio?
You can estimate your drive ratio if you can measure your speed and RPM accurately, your hull (bottom) is clean, and the engine is running correctly.
Using a
prop slip calculator , 24p props and approx 12% slip, you should do around 33mph at 3500 RPM if your drive ratio is 2.20:1
If it's 2.00:1 (which may be unlikely in a boat that big) you'll be a little bit faster (3 or 4 MPH)
It's also easy to do it by removing the sparkplugs.... turn the engine either by hand or the starter, while someone gently places the drive in gear......once in gear turn the engine exactly 2 revolutions and have someone determine if the prop turns exactly 1 turn (2.00:1) or slightly less than one turn(2.20:1)
Don't shift the drive unless the engine is turning.
