Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I have a 91 Johnson 200 tx and have lost all power to the engine & trim, I do think it is the main power fues but I can't find it, any help in locating it would be greatly appreciated, hate to take it in over a silly fuse.Thanks , Dan P
DFP..... Locate the main "RED" electrical plug at the engine. A short distance back (towards the engine side) you'll see a wire exiting the harness that leads to a small "RED" plug. That is the main fuse holder.
caution check that fuse . you can tell a lot by how the fuse looks.ie a glass fuse that has blown and<br />looks black and silver on the inside is the cause of a dead short. look inside a fuse that was over <br />loaded and the metal will look like it was just pulled apart. i learned this after years of trouble shooting<br />fire alarm systems . you can go through a box of fuses looking for a dead short on a moving part.
Yo catfish<br />next time you troubleshoot a burnt fuse condition, simply use a headlight to act as a fuse. Install it where the fuse connects(use jumper leads). Start wiggling wires and turn on accessories until the light burns brite. You've then found the short, and no burnt fuses.....
