timothys001
- Jun 4, 2003
- 8
i have a mercruiser 190.the engine runs well for about 10 minutes then it skips and want idle.you can check the oil before you crank it and it will be right where it is supposed to be on the dip stick.after the 10 minutes it will be to the top of the stick and look milkey white like water in the oil.let it set for a couple of hours and check it and its back right on the dip stick again.after the 10 minutes of running it blows the oil out of the breather like what i call blow back.any ideas what it is or what i can do to fix it.thanks in advance for your help on this matter.i read on another thread that no car motor would fit.is this true?thanks again.
