Hello - Not much success with last post...
I have a
1. 1987 Bayliner Capri 1950 Bowrider with original engine/sterndrive.
2. Its a standard 19 ft 6 inches.
2a.Its 120-130hp
3. Full with 30 gallons, and 2 children total of 90pounds, 2 adults total of 350 pounds
4. Use boat for skiing, fishing, cruising
5. Is it a Deep Vee, with unknown degrees to me of deadrise
6. 1987 volvo penta 275 engine, AQ131A
7. Gear ratio of motor -- Dunno...
I have a beat up, hammered back into reasonable shape michigan 14 X17 pitch prop.. This prop at WOT goes 33-34 mph planes at 20-25 mph at 5400 RPM... I used a 14 X19 pitch Volvo Penta prop which at WOT goes 34-35 mph, planes at 20-25 mph at 4500RPM...
I am wondering what my best prop would be for this boat..Wanna ski and cruise. I am curious about a 19 pitch 4 blade prop???Any ideas welcome..
Just got boat, engine compression is good around 170psi.
So I understand that the 4 blade prop gives a better hole shot, but would I go with the same pitch that I have now, or to a 19 pitch if its a 4 blade.. Is 34 mph about the top for this boat?
Also... I noted with the 19 pitch prop that the boat was harder to steer. The 17 pitch took almost no pressure on steering wheel to control, but the 19 pitch takes a lot more pressure/strength to turn and then it eventually seems to give and steer more easily (??maybe easier on plane) Thanks
I have a
2a.Its 120-130hp
