Re: Help removing broken screw
I just successfully removed 3 broken screws like yours from my motor last week, using a propane torch and vise-grips. If you can get vise grips on the one, I'd heat the surrounding aluminum with a propane torch; you won't be able to get it hot enough to do damage with propane and the large mass of aluminum will dissipate the heat quickly. When aluminum oxidizes around steel it grips it tight, getting fluid to penetrate is almost impossible (I always try it but it never helps..still, it can't hurt), heat is your best option. Heat the aluminum as it will respond quicker than the steel to expand and release it's grip and allow you to turn out the broken stud. You can drill out and heli-coil the other, but you better know what you're doing. I would not suggest using easy-outs in this situation, it would probably end badly. I think that Bob_VT has offered a good option as well. Good luck.
