Help setting up a trailer
Dennischaves
I just got this trailer
It had a 19' boat on it. Does anyone have any idea what model it is or weight capacity?
Im planning on setting it up for my 19' glastron trihull
The boat is a little wider than the space between the fenders so my plan is to raise the bunks so the hull sits above the fenders
(Thats how the old trailer was set up also)
Does anyone see any problems with doing this?
Welding is no problem for me as i do a lot of welding at work
Silvertip
It's a Tracker trailer. Model should be indicated on that tag (3rd picture). The title should have the serial number on it. Tracker would then be able to tell you what model it is. Capacity should also be shown on the tag. If its not readable, check the load capacity of the tires x2. 'That's the gross weight rating (trailer, boat, and all the stuff in it). That's of course the tires are the same size as originally equipped.
Dennischaves
I dont have a title (not needed to register)
And someone ripped the sticker off the tag
I will check the tires tommorrow
JASinIL2006
If you do much welding, I'm sure you're aware of the dangers of welding galvanized steel, but just in case you're not, be sure to read up!
