Help to connect harness
P1
Hi i have a harness of Yamaha 703 10pin and i make my own connection to fit my motor Yamaha 55 hp 1995 7pin motor harness the problem is from my switch there is a yellow wire that is mark on start but in motor there is'nt yellow wire so i can leave it out?
Remote Harness
Red/Green/Pink/Lightgreen/Brown/Black/Blue/White/Skyblue/Yellow.
Motor Harness
Green/White/Black/Pink/Red/Brown/Blue.
Can anyone help please help many appriciated
Regards Patrick
rodbolt
Re: Help to connect harness
yes, leave the yellow wire out.
also leave the light blue and light green.
your engine does not use the key on yellow 12V nor the light blue or green trim wires.
dark blue is choke,dark green is tach send,red is 12V supply,white is kill circuit,black is ground,brown is starter solinoid and pink is alarm.
P1
Thank you very much for your help you'r great.You help is so appriciated.
Regards Patrick.
