Help troubleshooting spark problem on 9.9
Lion hunter
I just got this motor so I am unfamilar with it. 1986 9.9 with electric start. Motor cranks good but I have no spark. I don't have a manual yet but I searched enough to run some tests. Could some look at my results and see what they think is the problem.
Ohm test on sensor from the white/black to black white (B&C on the female plug) = .44
Ohm test on power pack black/yellow to white/black (B&E on the female plug) = open both ways
Ohm tests on coils (both are the same results) :
Primary to plug= .27
primary to ground= 0000
plug to ground= .27
Volt test on black/yellow wire on key side w/key on .33V w/key off 0 V
My guess is that the power pack is bad but I want to verify before I buy one.
Couple other questions:
1.There is a blue and red wire coming from the solenoid box that are not connected. I am assuming these are the kill switch wires for the tiller model. Is this correct?
2. How would you test the coil laminate assy. under the flywheel?
Lion hunter
Re: Help troubleshooting spark problem on 9.9
Forgot to ask, is there anything else I should be checking. If I have to order parts from iboats I want to do it all at once.
