Hello all,
I'm a new boater and I bought an old boat. Don't assume I know anything because I probably don't.
My boat is an old Bayliner with a Volvo AQ125A/270 stern drive setup. When I bought the boat the raw water pump wasn't moving any water. I took the water pump apart and replaced the shaft seal, shaft, bushings, and impeller but still no pumping. The only parts I haven't replaced yet is the housing and the cam.
First, is the impeller supposed to fit really tight? The "fins" on the impeller were overlapping the housing by a good bit and I had to twist and force it down in there. Is that right? Is there a wrong way to put it together?
If it sounds like my water pump went back together right, what else could be the problem? I'm to the point of tearing the thing apart to look for obstructions but would really like something easy to check first.
Any help is appreciated. Thanks!
-Mark
-Mark
