Stevo_FourWinn
- Mar 25, 2013
- 2
Hello All, I have a 2007 VP 4.3GL FourWinns with a SX-A drive. I noticed my trim/tilt sounded a bit slower in the past weeks. Now all I hear is a clicking sound on the relays and the Trim/Tilt doesn't raise or lower. After a bit of troubleshooting, I figured out if I lightly tap on the Trim pump it temporary works. Does this symptom sound familiar with anyone and would you recommend replacing the trim pump or are there anything else I should try?
***I have the newer trim pump that replaced the faulty one VP originally designed.
***Water and a yellowish fluid came out of the pump when I loosened the bolts to the unit.
***I confirmed the trim switch, fuses and relays are working properly
Thanks,
Steve
Thanks,
Steve
