Rough day at sea yesterday. I have a 1998 225 Evinrude. The power head was replaced going on 3 yrs ago due to a failed pump. I have a strange warning system. A beep every couple of seconds usually indicates the VRO tank is running out of oil. With that said it was full and the primer bulb was solid so I think it was working correctly but not sure. With the engine off I was able to prime that bulb and the motor definately reacted when I started it up again. We decided to drive and and manually pump the bulb to ensure oil was going through. The engine ran fine but the alarm would go off pretty consistently and we just kept priming the bulb. The engine smoked like a normal 2 stroke so this says to me it is getting oil. At least I think. Well we made it in and I immediately changed the fuel filter and found deposits of rust in the container. Took the boat out for a ride and all seemed well for a little bit. Then the beeping started again. We happened to notice the fuel primer not oil primer was a little soft but not collapsed. Maybe it's going bad? I have been pretty much freakin out due to the fact I don't need to spen $4000 if the power head fails again do to an oil injection problem but not sure if that is the problem. One more thing on my alarm system, I notice sometimes when I heard the alarm and shut the motor off and then just turned the key on but did not start the motor the beeping would be consistent. Wait like 15 minutes or so and it would be ok. Motor seems to be breathing ok and there has been no apparent performance degradation. I know this is a lot of stuff here but if anyone has any ideas I'd like to hear them. I'd really like to be able to make sure the VRO pump is working correctly but have no clue how to. HELP!!!!!!!! Thanks in advance.
