Hello-
I recently acquired a 1983 Bayliner with an AQ125A and 270 Outdrive. The boat has been taking on water and when I did some looking water is coming into the boat where the engine meets up with the outdrive (see yellow circled area in first photo).
I pulled the U-joint bellows and it has an enormous tear in the top of it.
My main concern is the U-joint. The bellows must have been torn for years as the U-Joint is very rusted. Some of the needle bearings are gone in the crosses and there is a lot of play in the joint.
Some good news is the oil in the intermediate housing was clean and clear so at least I know water isn't getting into the lower unit.
So, here are my questions:
1. Water getting into the boat. Should I be looking at other seals between the motor and outdrive or will the bellows replacement be enough?
2. Is there any hope for this u-joint if I get new crosses? I really don't want to but a whole new U-joint.
3. Besides the Bellows, bellow adhesive, crosses, two o-rings between the intermediate and upper housing, and a seal between the upper gear housing and cover are there any other parts I should replace or think about replacing while this is apart?
4. Do I need special bearing grease or will any bearing grease work?
5. I looks like everywhere there is an o-ring they also used Permetex Red. Should I do the same when I put this back together?
Thanks for all your help
