Re: Help! We're Going Through Registration ****
I had to do the same thing as Seaboo a while back here in WI. It is necessary that when the undeliverable letter is returned to you that you do not open it. This is to ensure that the envelope did contain a letter which should state something like: "Dear last owner, I purchased a boat which was last registered in your name with no paperwork. I need you to sign the enclosed receipt (write yourself a receipt) and return it to me with any titles you may have for this boat, etc. so that I may register it in my name and release you from any liability associated with it. Thankyou, etc." Enclose a SASE for the previous owner's convenience in order to speed up the results.<br /><br />One of three things will happen: 1 the last reg. owner will return your signed reciept which you take to registration authorities. 2 the last reg. owner will have moved or died and your CERTIFIED letter will be returned to you unopened. Again, do not open the envelope. Take it to authorities. 3 The owner will call you and the cops and come get his/her boat back.<br /> <br />You can find the last registered owner by asking the authorities with whom you register boats in your state. It worked very quickly here in WI but then we pay like 90% taxes so everything had better, right? Just document everything very carefully. This seems to be a universal method of claiming "abandoned property" and hopefully LA has a similar program. GOOD LUCK!
