help will not start
cobra120
i just bought a 19ft cobra with a 150hp force. i put a new water pump on the motor and could start it with starter fluid but had to keep it full throttle to keep it going . then fornd a blown head gasket and changed it and now it will not start at all. it tries but still nothing but a hope and the only thing i can think of is the stator is bad i dont see any bad wires .....:confused: and i have no manual, diagram, or serial number on the motor..:eek:
roscoe
Re: help will not start
Do you have spark?
Is the compression good now?
What about fuel delivery to the cylinders?
You really need a manual to troubleshoot.
QuadManiac
Also spraying starter fluid into a 2-stroke is damaging. It washes away all the oil that is in the engine and will lead to internal damage. You should use a spray bottle with fuel/oil mixture instead.
cobra120
i finally got it going i had a bad ground it looks like i ran another ground from my battery to the head and turns over great now:)
cobra120
i have my boat running but i have another question i am thinking bout selling this boat and gettin a bass boat but this is about an 81 bayliner cobra motor runs new floor just needs seat and new side panels does anyone know about what this boat would be worth also needs new clear coat on top?
