Help wiring a f100txrz
Hennysemitara
i recently bought a Yamaha f100txrz on Craigslist for $400, with no controls i took a chance maybe it runs good, looks in good condition, owner said that he bought the motor as a project but didnt get to it. i bought used control box 703 from a local yamaha dealer and it came with a 10 pin harness. im confused as to how to connect the 10 pin harness from the control box to the motor. the motor has a 6 pin and a 8 pin connector and the control box has a 10 pin. please help, i want to try get this motor running. Mahalo!
Hennysemitara
the yamaha dealer is closed on monday and im off on monday so id like to work on it. motor looks in good shape prop spins free, oil looks good and motor dosent look overheated it looks clean. i hope i scored.
boscoe99
Something is not adding up. An F100TXRZ should have a ten pin connector in the front of the lower cowling.
Hennysemitara
so there is suppose to a 10 pin connector right? i looked online and it has the same harness. i have it sitting starboard sude down so i cant see the wires.
boscoe99
Why are you showing us the 688-8258A-50-00 extension harness? That is a harness for a different application.
The ten pin harness that connects the 703 control box to the ten pin connector in the engine pan is a different part
number/different configuration. 688-8258A-20-00.
The 703 control box ten pin harness looks like item 49 in the illustration linked below. It has a ten pin connector at one end and bullet connectors at the other end.
https://www.**********/catalog/yamaha...e-control-assy
Hennysemitara
im showing the 688-8258A-50-00 extension harness because that is what is on the motor now.
Hennysemitara
your link dosent work
Hennysemitara
try check out my pic the top 2 connectors is what is coming out of the motor now, a 8 pin and 6 pin. the bottom connector is a 10 pin. the guy i bought the controls from said that the controls are made for my motor the yamaha F100TXRZ but they do not fit together that is why im stumped.
Hennysemitara
if i remove the extension harness, i can plug it directly to the main harness? like i said i cant see one side of the motor it is sitting on the starboard side
Hennysemitara
ok guys i figured it out like boscoe said, it is an extension. the main pin is under a plastic cover in the motor which i didnt see because the motor is lying on its side. good to go now! thanks everyone!
