help with 1973 evinrude 115 key switch
raync
I got a sierra mp39760 switch its a push button choke switch was going to by pass toggle to push button but was wandering if this switch would even work?
Silvertip
Confusing sentence but yes, your "push-to-choke" ignition switch can replace a choke toggle switch. You simply disconnect the wire from the toggle switch that goes to the choke (not the one with power on it) and then connect that wire to the "C" (choke" terminal on the ignition switch. You can use the toggle switch for something else if you wish.
