marceljigfisherman
- Apr 19, 2020
- 8
hello all
i am new to posting in forums so please forgive for newbie mistakes
i have been following several forums about my motors problem and possible causes so i will try to list everything i cant think of so here goes
1. motor starts and idles good
2. can run wide open for about 4.5 miles and then it starts missing and running rough and the rpms go down like it running about 1/2 to 2/3 open throttle. when it does this i can idle speed with no problems or missing.the 4.5 miles is a constant distance it has been doing this ( measurement comes from google earth).
3. things i have tried so far replaced hose on portable tank.
4. pump ball while it is acting up did not help. also pull out choke didn't help either
5. took cover off laid hands on head didn't feel extremely hot
6. pump ball up on tank at home it stayed hard for over 24 hrs.
7. took cap off tank made no difference (checking vent on cap)
8. have run seafoam in gas (double up on dosage a couple of times)
9. have run about 15 to 18 gallons of gas thru it since the middle of january thru april 19th
10. carburetor rebuilt about 6 years ago and new fuel pump about same time.
11. ran good last year problem started this year
12. changed plugs this year
13. look at plugs to day looks wet but not fouled
one question i have also can a condenser or coil being going bad when motor is running this long.
14.new hoses on carb and motor from about 6 years ago no signs of leaks under the cover
15. check the two pee hole below motor water coming out even when i rev motor more water comes out both holes
thank you all very much.
