help with 4.3 mercruiser knocking
Rbryan94
Went to start my engines. Starboard everything perfect! Port wouldn't start due to no fuel. Both engines share same tank. I took off anti-siphon valve and cleaned it. It had lots of snot in it. I checked all connections and tried again. The engine started but is running rough and there is a loud popping sound coming from the carb. It sounds like crap! I had no problem with these engines last year. I don't know where to start . Any feedback will be appreciated.
Bt Doctur
Re: help with 4.3 mercruiser knocking
what did the spin on filter have inside? could have had some water get into the carb
Rbryan94
I didn't spin them off. Just checked connection. Changed both in the fall. Does it sound like water to you?
Bt Doctur
yes,something plugged the carb up. pour them into a clear glass container
Rbryan94
So take off the carb and soak it? Oh you mean the water fuel separators? I get it
