jbing81
- May 22, 2010
- 421
Hey Guys!
I need a bit of help with the stock single lever control box that came with the '77 Mariner 85 hp motor I recently purchased. The linkages did not come attached to the control box when I bought it and Im having an issue connecting them. First off I think I have the two connected to the correct sides of the box. When I move the lever to the forward pos. the forward gear engages, then the throttle, and vise virsa for reverse. So that portion is correct. However when I lift the lever to disengage the drive shaft allowing the motor to rev. the shifter still engages the drivetrain.
Plus when I reassembled the box it wouldnt go together. I had to lift the lever that disengages the drivetrain to get the box to close. Could this be a part of the issue Im having??
I have included some pictures to help
This is the side I connected the throttle to
This is the side I connected the Shift linkage to. The large wheel in the center wouldnt accept the throttle side without me lifting the disegagement lever.
Please let me know if anyone can help
Thanks in advance
Jeff
Thanks in advance
Jeff
