help with adults only section!
bute56
I have been unable to get manual #15 off of the adults only section. Can anyone help with this. It starts to download, finally finishes but nothing shows up! I have tried a couple of times. I have an '89 Webbcraft 23' cuddy with the original engine and outdrive, Mercruiser 5.7/V8 Alpha One, Thunderbolt Ignition/Power Steering, Transom Serial #OC589823, Drive Serial #OC579936. Thank you in advance.
SuperDaddy
Re: help with adults only section!
Hope it helps. I just realized you may need a different manual than what I was referring to.
gshldon
make sure you are using internet explorer, i tried it with firefox and did not work.
So make sure you use internet explorer
bute56
Thanks for the replies! I am using explorer. I am able to get the manual for the Alpha One outdrive, but still no luck with the engine manual....
bute56
Right clicking on the link then saving is how I finally got it to work!
