sony224422
- Jul 15, 2006
- 67
I just recieved an 88 spl from my grandfather. Its been sitting for 4ish years, but it started right up. It idles fine and all, but since its been sitting, I want to do the impeller. Its nothing like my 1978 115 where you just unscrew the shift rod screw to drop it down.
It looks like some sort of pin that you push out, but I can't actually see the other side of it really. I'm new to these newer models, so im not exactly sure how it goes to get that screw/pin out.
So, do i have to remove the carbs to get to it, or does it just push out? I noticed there seems to be some sort of access port on the starboard side.
The only numbers i could find were 62966322
if that helps with the model number or year that'd be great.
thanks
thanks
