Help with aq125b. 87 bayliner capri
Josh5806
Hello I am new to boats and need a little guidance. I have recently picked up an 87 bayliner capri with the aq125b. It has a couple issues that i know of and could use some help. First is that the carb was just rebuilt but it will not start and run on it's own without feeding gas manually into carb. I noticed that it is not pumping gas from the bowl but it is full. The 2nd issue is that it drips from an expansion plug on the underside of the exhaust manifold when I have it running. The plug is not a concern and should be an easy fix. My concern is that it drips antifreeze and was wondering if it should have antifreeze in there as I thought only freshwater passed through it and out the back. If it is not suppose to have antifreeze in it, what could cause it? Any help would be greatly appreciated.
Ayuh,...... Welcome Aboard,..... Sorry I didn't find yer post sooner,..... Glad ya figured it out,.....
Josh5806
Yeah but the real problem starts now. The PO was a real piece of work. Found that the HE had a hole in it and had it repaired but when I removed the exhaust manifold to replace the plug I found that it had a "temp" rubber tighten down plug that looked to had been there for 5+ years and the exhaust manifold was cracked. Rebuilding the whole cooling system basically. Hopefully all goes well. I know I'm new to boats but come on. Winterize properly!!
make sure you check that mid 80's bayliner for rot in the stringers and transom.
