saltydog1973
- Aug 10, 2011
- 11
Hey guys...I have a few questions/issues I'm trying to work out before this weekend as my father is visiting and wanting to go fishing for a week. So before I start throwing parts at it I thought I'd check here.
Boat: 1987 Bayliner Trophy
Engine: aq131a
Outdrive: Volvo Penta 275
Over the winter here is what i had done.
Electronic ignition
Timing belt replaced
Oil change
And pretty much had him go over everything major
Here's the issue:
Won't go over 14 mph on gps (tach is inop so can't check rpms)
While trolling it will idle rough after a few minutes and stall then has a hard time firing again unless it sits for a few minutes
It has no fuel filter or water separator so I drained the entire tank and plan to install one and new fuel line
I checked to make sure it was getting fuel last time out when it wouldn't start and it was squirting in the carb fine...
I'm very puzzled as its a pretty simple fuel system/carb set up. I have been scanning the forums for a week or two now and see similar issues but not quite the same, and also don't see end results/solutions and the end of the posts...any help would be appreciated!!
Engine: aq131a
Electronic ignition
Oil change
Here's the issue:
