Re: help with batteries
Cold cranking amps is for starting batteries and that tells you how many amps your battery will supply at 0degF for 30s and not drop below 7.2v. MCA or CA (Marine Cranking Amps) is the same thing but at 32deg F. <br />You're more interested in the Amp-Hour (Ah) rating of a deep cycle battery. It tells your how long your battery will last before needing a recharge. That, of course, depends on your load, so you have to calculate it. For example, your lights are 55W. W = V x A, and say your battery is a 12v one, then A = 55W / 12V = 4.6A. Ah = A x h(ours) so a 100Ah rated deep cycle battery will last for 100Ah / 4.6A = 21.7h(ours). <br />Running the trolling motor will consume a lot more juice. Say your manual says it consumes 43A max. Your 100Ah battery will then last 100Ah / 43A = 2.3h when operated at full throttle. The trolling motor will consume just slightly above half that at 1/2 throttle.<br />If you insist on using an starting battery, which is a very bad idea as the above posters indicated, you should observe the RC (Reserve Capacity) rating of the battery. RC is the number of minutes a battery can supply 25A at 80degF and not drop below 10.5v, where battery damage gets much worse. So the equivalant of Ah for RC rated batteries is Ah = RC / 2.4.<br />Keep em cool and keep em fully charged and you'll get a lot more life out of you batteries. No battery likes to be fully discharged.
