I just purchased a used 1995 Proline 220 Cuddy/Fish. It has the standard 5.7L V8 MercCruiser and upgraded Bravo I outdrive. I am having a big problem with the prop cavitating. The boat will not get on plane without using full down trim tabs. From idle (with trim tabs up), the boat starts to accelerate as you advance the throttle forward. As the boat begins to plow (prior to getting on plane), the prop begins to cavitate. RPMs go up, and acceleration decreases. The boat can never get on plane this way.
If you put the trim tabs down and repeat the same process, the boat planes fairly easily with only 2 people on board. I know the trim tabs should not be required to get on a plane however.
Two props, a 14x17p aluminum and 13.5x19p stainless came with the boat. I originally thought the hubs were shot, so I replaced the hubs in both props and tried both of them again- There was no change.
Given that both props cause cavitation, I do not believe it is propeller induced cavitation. I'm an Aerospace engineer- I know fluid dynamics, but can't for the life of me figure this one out. I don't believe the upgrade to the Bravo 1 outdrive should have made a difference. I know Proline recommends a 14x19p prop. Both of mine are in that ballpark, so they shouldn't make a big difference either.
Thanks so much for your help.
