nola mike
- Apr 22, 2009
- 5,695
Had some fluctuating voltages last year after installing the new engine. Didn't stay very long, but would overcharge for maybe 30 sec, then undercharge. Took the boat out for the first time this season, and on the way out my voltage spiked to 18v for a minute before settling to 14.2. after a while it dropped to battery voltage (12.7) before getting back to 14.2. on the way home it charged for a while before again dropping to 12.6 for the rest of the trip. I thought it was the voltage regulator, but I swapped in a spare alternator and am still not charging. Engine starts and runs fine, and I'm getting 12.5v from the battery when running.
1. Just to make sure my wiring is correct: My old (I think original) alternator had a purple lead hooked to purple wire, and red wire connected to red wire. There was a B+ post for the orange wire and a separate ground stud. "New" alternator has red wire, which I connected to red, black wire that I connected to purple, B+ terminal, and a ground lug (I think) attached to the frame screws. I hooked red to red and black to purple.
2. When started, I'm seeing 12.xx at the red wire, and 11.xx at the purple.
3. I'm also seeing 24v (?) from the orange wire to engine ground with engine running.
4. I thought that would mean I'd have a problem with the 90a starter fuse, but with the engine off I get 12v at the orange wire. Access with a hot engine made testing more around the starter difficult.
I'm a bit frustrated so probably missing something obvious, but it seems like the alternator is both putting out too much voltage, but it isn't making it to the battery. Because of the symptoms, I originally just assumed that I had a bad regulator and didn't test the old alternator outputs before swapping.
