Help with Eagle Fishmark 480
B1gGr33n
Hey all! Think I'm gonna like it here!
So I bought this sonar at a Savers thrift store for $4.99. Figured at that price, it was worth a shot. The problem is it doesn't have a transducer, and none of my buddies have or know someone who has one that would work to test it. I'm hoping that before I go drop $65+ on one, someone could tell me which probes are the power probes so I could test to see if it even turns on? If anyone knows which ones, please do inform! Thanks!
B1gGr33n
Re: Help with Eagle Fishmark 480
Thanks to Silvertip for trying to help, but unfortunetely I still don't have a solution.
dirtmod61
If you're looking at the back of the unit, the left side plug is power/transducer. The top and bottom pins farthest left are power and ground. The plug on the right side of unit is a hook up for additional speed/temp sensors. Hope this helps.
B1gGr33n
Thanks you dirtmod61, I'll give that a try
B1gGr33n
Well I couldn't get any response from the unit that way. I'm going to check ebay for a demo cord like they use in stores.
dirtmod61
That's how I checked both of mine before I installed them. If you hooked it up correctly, I personally wouldn't waste any more money on it. Bad head unit. Sorry I couldn't help out.
