Looking for OB Motor help-
Seaswirl w the Evinrude 150 Oceanpro
Check Engine Light is on (fuel issue)
Ran tough at idle
Blowing white smoke
Always get the same gas and use same fuel stabilizer.
Replaced fuel/water separator filter.
Removed and cleaned fuel filter.
Pulled plugs they all looked good (champions) and I re-gapped them back to .30” (they ranged from .32” to .40”).
Sprayed carb cleaner in the 6 carbs.
both fuel and oil primer bulbs stay hard after start up.
***Check ENG light is on before motor cranks, no alarm with it.
Does anyone have any suggestions where to go next?
Ran tough at idle
Blowing white smoke
