Help with Force Tilt and Trim Installation
lso254
I just bought a new quicksilver tilt and trim kit for my Force 85HP on Ebay. It has a lot of parts can anyone steer me to installation help? Moter is a 1984, (USmarine) Model is 856X5L, Serial number 7100. The trim Kit is F5H149-1 which supercedes to 853515A3. That's a whole lotta numbers-help appreciated to save $$$$.
12Footer
Re: Help with Force Tilt and Trim Installation
Welcome to iboats. It should bolt right up. It's not easy, but well worth every bloody knuckle. I want one sooo bad for my Force50, after running the same type engine (my nephew's)..What a difference! I keep trying to talk hin outta the unit, but no way (he has experianced my engine).LOL.
EatMoreFish
12footer....your a fl boy right? I have a 1994 force 90 hp maybe we can work out something
93bronco
Ensign
eatmorefish is that force 90 for sale? :confused:
EatMoreFish
Well....It broke a ring on number 2 cylinder so I was going to rebuild it (block was fine) Flywheel would not come off I tried every thing heat hammer and all.. now the flywhell is bent. I found a good 120 for what it was cost to rebuild the 90. So I got it. I removed the starter and other parts that would fit my 120. If you want it in this shape let me know maybe we can work out something
lso254
Getting the parts pieced together now, does anyone know-do the relays (2) attach to the<br />power head. If so, where does 12v current attach?
