Help with FrankenJohnson Pivot/Stern mounting
Wildey
Hi folks, hope some of you Johnson gurus can help me.
Something appears to be changed, swapped and/or missing.
Sticker says J40ELCEC.
It was mounted on a CMC T&T kit which will be used elsewhere.
This motor will go back on as manual t & t.
This bracket has the 2 position padded flip stop for tilted UP and Down but when down, the trim adjustment pin never comes close to reaching the stop on the housing. Not even close, even in the closest hole position (trimmed UP).
Also, looks to be a lever to lock the motor from tilitin up when in reverse. All of the associated goodies are gone from that (if that is what it is).
The only diagram I can find that comes close does not match the model # but some of the actual part numbers do.
I cannot find an illustration of what is missing and what I evidently need.
Thanks for any help, greatly appreciated.
W
Wildey
Hmmmm, stumbled across mention of a Tilt Assist cylinder. Followed that lead to a vast amount of info. Pretty well explained all I need to know .... for now, anyway. Might have to change plans for the CMC. Was going to maybe sell it.
Carry on folks, I got this one :) (y)
saltchuckmatt
Usually eBay has some.
