Help with gas tank and hose for 1996 Mariner 9.9
j_dent3
Hi
I am fairly new to outboard motors so my apologies if this is a dumb question. I bought a 9.9 hp Mariner motor. It is a 1996 2 stroke. The motor didn't come with a hose or gas tank and I need to buy one. Where can I get one online in canada for a good price? Also do you guys think this was a good deal for $900? Thanks!
carholme
Re: Help with gas tank and hose for 1996 Mariner 9.9
Do you have the s/n of the engine?
Gerry
j_dent3
Ok the serial number is 06376964
carholme
I believe that should be 0G rather than 06. If so, it comes up as:
MARINER - ( 9.9 H.P. (1996 ))
Serial No: 0G376964 Model No: 7010201ED
Parts list for model 7010201ED:
6/8/SAILMATE 9.9/SAILPOWER 15 H.P. - Mercury, Mercruiser, Force, etc. Parts Lookup
The service manual you require is P/N: 90-827242. If you do not have this manual, see my message to you in Notifications at the top of this page.
Where are you located? Any Canadian Tire store of a decent size should be able to provide the fuel tank:
6-Gallon Fuel Tank | Canadian Tire
You can buy the primer bulb and hose at most WalMarts but they tend not to be the best, You should really pick one up at a Mercury dealer in your area. Or these:
Amazon.com : Generation III Fuel Line Johnson Bulb : Boat Fuel Flow Instruments : Sports & Outdoors
Gerry
carholme
I'll send you another email with pictures from a different site as Iboats doesn't like the competitors links and blocks them out.
Gerry
MH Hawker
It will have a Yamaha fitting on the motor end and a merc on the tank end, while that one you listed looks like it will fit fine, it it dose have the gray hose that will eventually cause the line to plug up.
