help with gear.
Apadilla
I am 6.7' and 250 pounds .I need help with the the right beginer board binding combo. Thanks for any help.
rallyart
Re: help with gear.
Apadilla, you want to try on boots. If you are 6'7" your feet may not fit many of the kit boots well. It is more important that you have boots that are comfortable and give you control than a board that does anything special. Look at getting a board or boots that are old stock. You can sometimes get very good value and end up with a better product.
Good luck
bowler
Re: help with gear.
Good luck
agreed. good bindings are your main priority.
