minuteman62-64
- Apr 12, 2011
- 1,350
Can anybody tell me what these fittings are called? And a source? They are used in a through-transom application to compensate for the angle of the transom.
Also, I'm looking for a source of 3/4" I.D. pvc/nylon/plastic tubing that is straight threaded (not pipe threaded) for the entire length.
I'm looking for a way to replace some fittings that were used to install the intake for a bait pump through the transom plywood reinforcement and aluminum skin of my aluminum Bayrunner. I'm removing the bait pump, and want to plug the hole with some fittings that will let me use it as a water intake sometime in the future. It would be easy if not for the fact that the transom is angled and the existing hole is horizontal.
