HELP I just changed the Impella on my 1994 150HPYamaha. Is this normal or not. As soon as the engine started up I did not have any water peeing out Now out of caution I turned it off. I did not let it run more then 5 or 10 seconds. Is this normal or should I let it run a bit longer to build pressure and see if it will come out?? The only thing that should be noted was when I replace the Impella with the new one. I had to use the old housing and the old stainless steel cup instead of the new one. The reason was the new stainless cup would not fit or lock into the old housing. On top the new cup was 2 raised tips and the old had just 1. So it would go back correctly I used the old cup. Do I have anything to worry about or did the Impella go on backwards??? If fit thur the knotch/key correctly. Im going to take it back apart and put the new housing. When I was replacing it the dealer did not have it in stock. Do I have anything to worry about. Thanks for any fast response. Help
