jbjennings
- Jul 18, 2007
- 3,903
Guys,
I've disconnected the fuel line from the filter to the bottom carb and the fuel pump will pump no fuel when starting it. So I disassembled the fuel pump and can't figure out what the problem could be.
It has a diaphragm gasket between the pump and block. On the pump side of the diaphragm, there is nothing but 2 check valves which were both mounted in the same direction. Is that right??? I see no other parts in the pump.
Is the pump missing something?
Can someone help or give me a site that will have a blown up view of the pump and its pieces?
I'm at a standstill.....can't figure out why it won't pump!
Thanks,
JBJennings
Thanks,
JBJennings
